주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
EFI password reset, blinking folder? Death.
I'll get right to the point here. I attempted an upgrade from Lion to Mountain Lion. After the reboot, a blinking folder of ? death occured. Tried every keystroke I could find on the Internet to revive it, to no avail. I've tried to boot from my disk, and also from USB. Using multiple keys, multiple times. Option key is the only key that gets a rise outta my Mac. It displays the EFI password prompt. A password that was set by the previous owner I assume. I've attempted the ram removal trick which only makes a beeping sound. I've tried it with 1 stick in different slots and switching them around. Ugh.. Any other insight would be mucho appreciated. Oh I also bought a new HDD hoping I could just fresh install. Same problems. Help me? :(
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Try this:
How do I reset the firmware password on my MacBook Pro?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks. I meant to update this earlier. It turns out that I didn't try with the ram in the top slot. That worked. Pulled out the top stick, then the bottom, then put one back into the top slot. Turned it over, powered it up, held down the 4 keys to reset the PRAM and it worked!! Unfortunately, all my mischief under the cover caused my screen not to display a picture. It lights up but is black. :( Not sure what I did yet.
댓글 달기
how to fix bios password for mac book pro uni body ....It is harware or software to fix it this problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I think you can try to visit http://www.recoverlostpassword.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This site is for windows user only., not for Mac
댓글 달기
귀하의 답변을 추가하세요
mrmjweber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 5,214
