주요 콘텐츠로 건너뛰기
모델 M8413 또는 A1007 / 600, 700, 800, 또는 900 MHz G3 프로세서
36 질문 전체 보기
Display is Dark like no Power
The iBook has no Display not even faint with flash light held to it. Connected it to an external monitor still nothing the external monitor shows "NO SINGNAL" you can hear it boot up and when you push the power and push return it powers down you just can’t see a dam thing….WTF
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
iBook 12” Model #A1005 800MHz/128MB/30GB/Combo.
댓글 달기
답변 1개
선택된 답변
Sounds like the GPU has gone belly up. No fix but to replace the motherboard that I know of. I can direct you to the correct motherboard given the exact machine specifications.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Dam I was hoping it would be something easy like slapping it, Haha. Any way it is a Apple iBook 12” Model #A1005 800MHz/128MB/30GB/Combo.
So if I have to replace the Logic board can I up grade it to the next board 900MHz?
The iBook video is part of the Logic board?
Where can I get the best deal for replacement board?
I didn't see a logic board on the parts list. But inventory is constantly changing and they may have one and just not put it up yet. You can contact them here. http://www.ifixit.com/Info/contact
As far as an upgraded board the person you need to talk to is Ben Eiseman, best parts man I know and he should be around in the morning.
The GPU is part of the Logic board isn't it???
I found some Logic boards on the net but how do know the correct part number for my iBook's logic board?
The GPU is part of the logic board. Wait for Ben.
댓글 달기
귀하의 답변을 추가하세요
Pssh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,475
