Another name for a motherboard?
Is there another name for a motherboard?
좋은 질문 입니까?
Logic Board is most commonly used around here.
해당 답변은 도움이 되었습니까?
Additionally, motherboard is usually written without the space (i.e. not mother board).
Other names of MOTHERBOARD are 1. Main Printed Circuit Board; 2. Printed Wired Board (PWB); 3. System Board; 4. Main Board, abreviated or shortened to MoBo.
as others have already said Logic Board is the other commonly used term. I've heard Apple refer to it as the MLB or Main Logic Board, too.
the term motherboard originates from early days of computers where the main circuit board contained the CPU and other major "logic" or chips, and usually also expansion slots. You could plug "daughterboards" into those slots to expand the functionality of the computer - e.g. printer interface, sound card, graphics card etc. That was a distinguishing feature of a motherboard.
p.s. to get into even more background of the terminology, the "board" part of this comes from the general term Printed Circuit Board, or PCB. this is the physical, non-conductive board on which there are conductive traces connecting the various electronic components. Logic board is just another way of referring to the PCB containing the major "logic" or chips of the computer.
해당 답변은 도움이 되었습니까?
excellent +
And then you have the grandma board, uncle board, and nephew boards.
Sometimes the motherboard is also called the mainboard. That's a pretty old term, but I've seen it pop back up in technical literature from time to time.
해당 답변은 도움이 되었습니까?
Mobo is an appropriate slang term. Smartly saves specious speech syllables.
해당 답변은 도움이 되었습니까?
Capital (MOBO)
I have been an electrical engineering technician for 25 years and have called them "System Boards".
해당 답변은 도움이 되었습니까?
The previous two are correct- Logic Board was mainly used as a term for MBs in earlier macs, however the term has stuck.
해당 답변은 도움이 되었습니까?
Motherboard is the main printed circuit board (PCB) found in computers and other expandable systems. It holds and allows communication between many of the crucial electronic components of a system, such as the central processing unit (CPU) and memory, and provides connectors for other peripherals.
해당 답변은 도움이 되었습니까?
The A+ exam used to call them Planar boards, and IBM/Lenovo uses that term.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 13
30일 전: 22
전체 시간: 27,963
댓글 7개
How does that increase the lifetime of devices?
rab777hp 의
I think this is a valid question because a common nomenclature is a critical underpinning of communication repair information. This is a common beginner question-- motherboard is actually a more commonly used phrase, but the Mac industry calls it a logic board.
Kyle Wiens 의
They are called "mainboards".
emplehod 의
They are also called MOBO for short.
JOSE DIAZ 의
I call mine Maxine.
emplehod 의
댓글 2개 더보기
