주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Unexplained, random power offs.
Over the last week or so my iMac has been randomly powering off. Especially at moments when I've written really well formed paragraphs for my master's thesis, yet before OpenOffice has auto-saved. I've checked the console log and there does not appear to by any particular software issue related. My guess is a bad power supply.
Has anyone else had a similar problem or suggestions for diagnosis? I'll probably try a fresh install of OS X before I drop $120 on a new power supply, but I'm not sure that will help. I haven't made any major changes to the OS or the iMac in the past couple of months. The HDD was upgraded to a 1tb about 6 months ago and the superdrive needed to be replaced about 5 months ago.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Try first resetting the SMC. Also try using a different power strip/wall outlet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
The SMC! Thank you. Hadn't thought of that. I had to re-set it once a year or two ago when the fans came on at top speed.
Several hours and no random restart. I'll report back.
Within moments, literally, the iMac decided to spite my words and shut down.
Sounds like a bad power supply then, have you tried my other suggestions?
I put a reconditioned power supply in yesterday. No luck in solving the problem. Everything was fine until a few moments ago.
I'm beginning to think our house may have an electrical problem, which is odd. i've only been here a few months but haven't had any issues up until this started a week or two ago. No major changes either. I just ran an extension cord from a different circuit to the iMac in hopes that I can just get it to work long enough to finish my thesis without remembering to save after every three words. I'm also going to buy a voltage regulator to see if that does any good. A friend just suggested there may be surges that are tripping the power supply to shut down the iMac but are too low to shut down the power stip it was on.
Solved. I purchased a voltage regulator and the iMac has now been on for nearly four days straight with only one reboot that I initiated. In related news, I learned the wiring in my house is terrible and will likely need to be replaced. Thanks for the help.
댓글 달기
귀하의 답변을 추가하세요
EvanB 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 848
