주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
iPhone 3G lcd screen burned up after digitizer change. What happened?
Hey everybody i got a little problems here with my iphone lcd screen. And im hoping that some of you could help me with this...
Before i changed digitizer to my iPhone, my lcd screen was working well. Now after digitizer change i noticed black burns in the lcd screen. When i start up the phone over half of the screen has black burns and colourful stripes and in the other side i can barely see some graphics but in negative colour. The questions are:
What did i do wrong to cause this to the lcd screen?
and
Can this be fixed with a new lcd screen?
The screen looks like this (sorry for the crappy quality):
Thank you alot!
- Heikki
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Maybe you have endommaged the LCD flex cable when you replace it on the middle bezel assembly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your quick answer. Umm but you mean i damaged the flex cable? Are you sure that its not just the lcd whats broken?
By the way there might be a chance that i accidently connected the wires to the lcd screen while the power was on. Not really good for the lcd right?
댓글 달기
Judging by the look of the screen the first thing I would replace would be the LCD. If that doesn't work you may have fried the mainboard but I doubt it will come to that.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your answer Peter! Yeah i just ordered new lcd screen and going to change it soon. Lets see what will happen. I hope the problem is not the mainboard...
댓글 달기
you should use the iPhone 3G lcd screen which is pre-assembled like this iPhone 3GS Replacement LCD Assembly I replace it with my iPhone 3G, no any problem..........
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the suggestion! but i already ordered a new lcd screen. Im gonna see whats going to happen. But good suggestion not an expensive price at all. Maybe i will order that if the lcd change doesnt help.
댓글 달기
귀하의 답변을 추가하세요
MrMouse 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,536
