Why has my screen gone dim but it still works
dark screen but still works
좋은 질문 입니까?
The first thing to try is a hard reset. You can do this by holding the home and power buttons in until you get the power off slider up the top of the screen. After it has shutdown power it on again and see if it has fixed it.
If that fails then I would assume either the LCD or 6R8 coil is dead. Before you go ahead and replace anything I would first inspect the mainboard for corrosion and if you find any clean it with isopropyl alcohol.
If after a clean it's still not working then I would first replace the LCD and if that fails then take it to a repair store to have the coil replaced.
I hope this helps and best of luck with the repair.
해당 답변은 도움이 되었습니까?
on ipod classic you cant hold home an power off. this is for i pad/iphone
I have had the same problem and I tried taking apart my iPod and unplugging, and reconnecting the LCD screen connectors to the logic board but it didn't do anything. I then tried resetting the iPod, but that didn't fix it either. I think once you have this problem it is time for a new device :(
I also saw a video where a guy replaced the LCD display and it still didn't fix the problem.
해당 답변은 도움이 되었습니까?
I held down the button and asked Siri to brighten the screen. it worked.
해당 답변은 도움이 되었습니까?
Sometimes a stray thumb can unwittingly reduce the brightness, why or how I do not know. Went to SETTINGS then DISPLAY/BRIGHTNESS then moved the slider up from minimum. How it got there in the first place I cannot say but for me a simple solution.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 11,216
