주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
iPhone 4s Screws losing 5-point pentalobe
i recently tried to replace my front glass panel and came to a major hault. i made the mistake of not buying your kit and instead bought a cheap screwdriver which resulted in one of the screws to lose its 5 point pentalobe turning it into a stripped screw head. i am now stuck with a screw i cannot remove in order to replace my front glass panel, is there any tool you would recommend beause ive searched but nothing seems to be thin or strong enough to grasp the screw.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 1개
선택된 답변
First, I would take a look at this list of the 12 best ways to remove stripped screws, to see if anything there can help (the rubber band trick is surprisingly effective).
Also, if the screw isn't stripped too badly, you might get lucky and still be able to get it out with one of our Pentalobe Screwdrivers. Since you're going to have to replace the broken screw anyways, it you might try the driver in our iPhone 4/4S Liberation Kit, which comes with two Phillips screws to replace those pentalobe screws for good.
As a last suggestion, iFixit also has a Precision Screw Extraction Kit that should be able to pull out the screw giving you trouble.
P2 Pentalobe Screwdriver iPhone 이미지
상품
$5.99
Precision Screw Extractor Set 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Sean Padilla 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,521
