주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
What exactly tool I need to open the MBA
Hi everybody,
I spill coffee on my MBA. Everything is running well. I see a tech that explain that the motherboard is not touched. They don't clean up the laptop. So i need to change the uppercase and the keyboard.
I would like to open the laptop. I would like to clean up the keyboard and the uppercase because therre are sticky. But i would like to know what kind of tool i need exactly?
On this tutorial, they say that i need 9 mm 5-point Pentalobe and 2.6 mm 5-point Pentalobe.
See: MacBook Air 13" Mid 2011 Upper Case Replacement
My question are
Do the pentalobe screwdriver open the booth size?
See: P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Do i can put the keyboard in the hot water and dry it?
Thank you very much
P5 Pentalobe Screwdriver Retina MacBook Pro and Air 이미지
상품
$5.99
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The keyboard can be washed... it may or may not start working again. (Nothing to lose, something to gain by trying). Be certain you dry it well before applying power (72hrs in a desiccant or 24hrs of low speed warm air in a container)
Required Tools:
  • T8 Torx Security Bit Screwdriver
  • Spudger
  • T5 Torx Screwdriver
  • And the Pentalobe Screwdriver
Good luck
If this answer was helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
bongshu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,631
