주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Can Apple Tell If I Dropped My Phone?
Are there any sensors in the iPhone that indicate that the phone has been dropped that apple could use to tell me my warranty is void? I know they have moisture indicators, but never have heard of shock indicators.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Yes, they can tell that you dropped your phone I have just been to the apple store to run diagnostics on my iphone 5 and they told me thy i had dropped it 4 times, which was true. I never asked how they knew as i was worried that it might void warranty (but it didn't because the dammage wasn't directly because of dropping - it was a speaker problem not a cracked screen for example)
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
say what? maybe they can check the gyroscope history?
댓글 달기
They can use the accelerometer logs from the phone itself to tell instantly. Also damage even subtle is noticeable on the inside of any apple device.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
No there is not shock indicators in any iPhone Apple has made. It is too expensive to place that time of tech inside a device as small as an iPhone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
It's called an accelerometer and it is indeed inside the iPhone.
iPhones have had access and gyros for some time now.
@Barack Trump You do realize this post is over 10 years old, don't you? There's really no point in responding to these very old questions unless you have significant new information to add, which I honestly don't see in your response.
There are many recent unanswered questions that could better use your input and experience.
댓글 달기
귀하의 답변을 추가하세요
christopher 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 102
전체 시간: 18,521
