cooling fans won't work
fans not working, fuses are not blown, and tried to jump start from battery but still didn't work
좋은 질문 입니까?
좋은 질문 입니까?
dominic, if you connected a positive wire to the blue or blu/blk wire and ground to the blk one, the fan would have to come on. Of course only if connected it directly. If you did not then there is the possibility that you have a bad fuse #3 and #57 for the cooling fan and #58 for the condenser fan. You also want to check your fan relays. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
This is a great help!
Can I swap the two identical-looking relays -- the one for the condensor fan and the one for the radiator fan -- to check if they are both working without causing any damage? The radiator fan comes on but the condensor fan does not. Trying see what I need to replace.
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 19
30일 전: 87
전체 시간: 30,100
댓글 2개
You tried to "jump start" the fan directly from the battery? It still did not come on? Can you tell us how you did that?
oldturkey03 의
When my turn on my a/c the fans work but if I turn the a/c both fans turn off can somebody help me on this
Mary Williams 의
