주요 콘텐츠로 건너뛰기
iPhone을 직접 수리하는데 필요한 모든 것! iFixit에는 모든 iPhone의 무료 수리 안내서 및 분해 정보는 물론 은하계 최고의 교체 부품 및 도구가 있습니다.
36475 질문 전체 보기
iPhone Soldering Practice Advice?
I am teaching myself how to solder and i am at a point of being comfortable trying on smaller things such as iPhone LCD connector and the 3 FPC connector for example.
Problem is i don't want to go guns blazing on a working phone.
Is there anything i can use thats cheap and wont matter if i miss it up that simulates doing it for real?
For example buying the 3 FPC connector and finding a board with the same pins to practise soldering it on?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 5개
Why not just start off by working on other logic boards? cheaper broken ones:-) If you need a cable 4th gen photo or 5th gen boards, let me know. Have plenty of those to play with;-)
oldturkey, what are those? I need something to play with removing a replacing components.. :)
those are iPod logic boards. they do have plenty of SMD components as well as FPC connectors:-)
Ohh! I'd love a couple of those to play with! How much do you want for a few?
Contact me by email (it's in my profile) :-)
댓글 달기
답변 2개
선택된 답변
Online in various websites they sell soldering practice kits of varying degrees of difficulties you can usually snag one for $25 with shipping. Or you can snoop craigs list for a broken down wreck and buy it cheap. I go to thrifts stores and buy the old cells that way for even cheaper.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I began practicing on a broken laptop wifi card. The chips and connectors are of similar size. There are also many different ways of doing the solder especially on the iphone since everything is so compact. Certain materials are recommended as well such as a no clean flux, desoldering alloy. You can also use a stencil for connectors with soldering paste and heat gun. Contact me if you need more information
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Craig 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 592
