주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Screen doesnt work after Front Panel Replacement
So I bought a replacement front panel for an Iphone 4S and the replacement process went well. But now after I have completed it and put the phone back together, it doesnt work. The backlight of the screen will light up and the phone will vibrate when I plug it in but there's nothing on the screen. I can connect it to Itunes and it recognizes it, so it seems that everything is functioning OK except for the screen. I have unplugged and reconnected the ribbon cables going the the screen multiple times but it doesnt help. I have also tried to clean them. Does anyone have a solution to this problem???????
Thanks in advance!!!!!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
It common for this to happen some times, But hopefully it not to serous.
try a reset - Hold power and home button for a few sec's.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hey thanks for the fast reply, I have tried to reset it but the power button is also broken and you have to push on it really hard. This makes it a little difficult to be able to tell if it is resetting or not. Do you think that trying a new screen could fix the problem?
댓글 달기
I am having the same problem the power button does not turn it on. And if I plug it in on charge the screen comes on but is really faint.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Electronics Man 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 885
