WD 2TB HD fit in a Mac mini 2012
HELP...
Will the new WD 2TB HD fit in the new Mac mini (as a 1st or 2nd HD)?
Thank you
좋은 질문 입니까?
HELP...
Thank you
좋은 질문 입니까?
Don if the 2 TB is what you need you can install two 1 TB drives with this kit.
해당 답변은 도움이 되었습니까?
Don - Don't know of a WD 2TB drive, can you supply a link about it.
What I can tell you is you need to use a 2.5" drive and you do have some head room issues (depending on the model), As your asking about the new '12 model iFixIt or anyone else has not opened one up yet so we just don't know whats inside for space and connections.
If Apple followed the last version two 9.5mm hight drives will fit. Wester Digital and heres the iFixIt guide on replacing the '11 model iFixIt Guide '11 model
해당 답변은 도움이 되었습니까?
해당 답변은 도움이 되었습니까?
Don - Its too high (15 mm) Sorry guy ;-{ Heres the spec sheet http://wdc.com/global/products/specs/?dr...
I Tried that 2tb drive it in my 2012 Mac mini. It is to high will not fit
해당 답변은 도움이 되었습니까?
It will fit. I have it in my 2011 Mac Mini next to an OCZ 256GB SSD.
The only way to get them to both fit is to remove the back plastic case/cover from the SSD and don't fix/screw the 2TB drive to the mounting frame.
해당 답변은 도움이 되었습니까?
Just don't ship the system or move it about to much as your likely to damage something as you have nothing anchored.
Agreed, but it is wedged in tight and I added foam/rubber pads to fill the 1.5mm gap. Should help limit/stop movement. Ideally someone should make an HD caddy/frame with the HD screw mount holes in different positions.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 8,356
