주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
How does the grounding clip sit
I have problems with wifi 3G switching and coming and going and it also effects the phone signal when talking they can here me but they are breaking up like the signal is switching masts as wifi and 3G comes and goes. I thin I don't have the golden folded over grounding clip in the right place but can't find an exact picture of it. Iphone4parts has the wifi tab being removed and you see the clip popping out but still not sure where it should sit. Help would be great thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Thanks for that but I looked at that bit which is grand it's just a metal clip came out under that and that's the bit I am not sure where it sits. Even on videos you see the clip pop out when you remove this grounding cover but none show how it sits back in
댓글 달기
답변 1개
가장 유용한 답변
Here are two photos from iFixit Guides showing exact placement of the clip.
http://guide-images.ifixit.net/igi/x1kpQ...
http://guide-images.ifixit.net/igi/ufYfT...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
See my added response above thanks
댓글 달기
귀하의 답변을 추가하세요
Joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,659
