주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
How can I repair my iPhone 3GS' speaker and motion sensor?
HELP! I replaced the glass with an iFixit part and guide, for my iPhone 3GS speaker and now the motion sensor and iPhone ear speaker (not speakerphone) is broken. I tried to reseat the cables multiple times and nothing worked! Any suggestions? Parts?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 2개
Brady, thanks for the input! I appreciate you getting back. I reseated the audio cable 5 times, while it was open i tested it, i think the heat gun may have damaged the sensor and the audio? What part can i buy, i need to get this fixed! The cable does not looked damaged. Any ideas?
Heat Gun?? you only need to use the heat gun for like 5 seconds on low. it doesnt take much to get the adhesive hot.
댓글 달기
답변 3개
가장 유용한 답변
It sounds like (no pun intended) cable #3 is not fully seated within the connector on the logic board or the connector/cable is damaged. Although you have tried re-seating this connector, it never hurts to try again. Also, does the cable itself or the connector on the logic board appear physically damaged in any way? Make sure the connector's locking bar is flipped up before sliding the cable into the connector. Good luck!
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
In reply to: Re: How can I repair my iPhone 3GS' speaker and motion
sensor?
Brady Cabe wrote:
Although iFixit does not sell that part individually, the
contains iPhone 3GS display assembly that cabling. Good
luck!
Brady, not sure what you mean here, by "the contains" please advise! thank you.
It looks like a few words were missing there. Ha, sorry. What I meant to say is that the iPhone 3GS display assembly contains the cable you need to replace. Granted the part includes much more than you need, but because that cable is not sold separately, that is the best thing I can suggest at this point. Sorry I don't have a better answer for you :(
댓글 달기
@ollie: it's normal that there's some space in between the white line and the connector. I've repaired several iPhones and I've never managed to get the cable in any further. BTW, dunno where you read that crap, but the lock is never gonna close by itself, no matter how hard you push the cable...
@the others: sorry for posting this as an answer, but I can't comment (yet?) and I couldn't find any PM system or the like
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
im having the same problem, i just chanced the camera
my prox sensor, speaker and my lcd backlight is gone
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
If the above answer did not solve your issue, please star a new question and state your symptoms. This question is 2 1/2 years old.
댓글 달기
귀하의 답변을 추가하세요
Mike Larson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 18
전체 시간: 43,345
