주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
replaced dock connector because of sound issues. Now new problem.
I purchased here and replaced dock connector. Unfortunately it did not help my problem. Iphone still thinks it is docked and consequently emits no sound. Speaker works while making calls.
There is however additional problem. Before the repair I could play music when phone was docked, but now it doesn't play. The only way to listen to music is via headphones.
Is there anything else I should try?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I just escaped this issue, what i did was put it into the dock and bent the phone forwards, now my phone has been fixed, i really hope this solution works.
Danny
Update
Sorry I couldn't help,
I found the common issue luckily! It's mostly water damage and can either be dried or replaced!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Is your phone under warranty? Apple should fix it.
Thank you for the advise. Unfortunately it did not work.
I decided to revert to old water-damaged dock connector and it restored some functionality namely iphone play music while docked.
This leads me to believe that I purchased faulty part form ifixit. I will attempt to seek replacement.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 846
