주요 콘텐츠로 건너뛰기
Looking for replacement battery for Logitech MM50 S-0173A Speakers?
I have a Logitech MM50 S-0173A speaker dock. Anyone have any clues as to where I can find a replacement battery for these iPod speakers from Logitec? I've tried Logitech - their answer is "we no longer make this device" - not a great deal of help!!. The battery is about 1/2" dia x 2" lithium, 3.7 volts.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Need to know the model number of the battery to find it. Ralph
댓글 달기
답변 4개
선택된 답변
OK try this one. Scroll down the left side and you will find a possible battery for your needs. Ralph
http://www.surplustraders.net/a/0696.sht...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I did a quick search on ebay http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
Update (04/26/2010)
It uses any 18650 battery. They can be found in many consumer goods. IE Laptop batteries.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
here is the replacement battery for Logitech MM50
http://www.batteryforum.org/t887-logitec...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Like EKWF said (#comment229709), a Logitech mm50 battery contains a single 18650 cell. Its battery cell is soldered to a protection circuitboard, and surrounded by insulator skin (heat shrink tube). Its battery protection board connects to mainboard through three wires: black (battery negative), red (battery positive), and white (NTC thermistor between black and white, if I recall correctly, but check yours to be sure). As simply one cell comprises its battery, it can be re-celled fairly easily. This battery is discussed in some detail, with pictures, on iLounge. (Topic: Logitech mm50 & Pure Fi anywhere batteries)
Logitech mm50 has an inlet for an external power supply. Its power plug is a coaxial barrel, outer diameter 3.5 mm, inner diameter 1.1 mm (approximate), insertion depth 8 mm. (You might scavenge a perfect replacement barrel plug from Nokia equipment.) Its original power supply is nominal 12 VDC, 1.5 A, centre positive.
If you are looking to make a replacement power supply (repurpose an AC adapter and splice a plug), then your replacement MUST have regulated output. (Non-regulated "old" style wall warts, big and blocky with a hot transformer, output a wide range around nominal rating. A piece rated "12V" might output nearly 20V while not loaded. Power capacitors in mm50 are rated 16V.) I suppose a one amp supply could suffice, but not much less than that: mm50 draws more than one half ampere when quiet and idle and iPod is not present.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
flipinoz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 17
전체 시간: 6,673
