주요 콘텐츠로 건너뛰기
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 질문 전체 보기
Is the glass the same as the iPad 3?
Looking to get the glass replaced on an iPad 4 and have the iPad 3 glass on hand. Wondering if they are the same? Didn't see a definitiv answer on the tear down but I'm assuming they are? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 9개
선택된 답변
So I just tested an iPad 3 Digitizer and LCD, They Work. They are fully compatible with each other.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Thanks, that's good to know because the Ipad 3 digitizer sell's for around half the price the 4 does !
댓글 달기
No they don't different length a width in flex cable yea the cable connects and works but fitting the flex between the LCD and frame is a nightmare just buy the screen for the model iPad you need.. Tryed and tested yesterday and both flexes have a slight difference
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Additionally, the iPad 3 glass on the iPad 4 leaves a noticeable (1.5 to 2mm) gap.
댓글 달기
Hi why would you want to use an ipad 4 touch panel on your ipad 3 for?, if you see a pattern most likely it is not the same, what i mean is if you compare Ipad 2 touch panel and Ipad 3 touch panel cable, they are not the same, so most likely not the same connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi thanks for the response. We actually got our first iPad 4 in and the iPad 3 glass worked perfectly fine. It has the same connections and everything. Not sure about the LCD since that didn't need to be taken out but we think that is the same as well.
댓글 달기
I used an ipad 3 digitiser and it worked
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
then means that the screen ipad 3 serves for use in 4? is the same connection?
댓글 달기
Ipad 3 glass works on ipad 4. Tested and confirmed.
Watch out for the home button though as there's a flex cable that runs to the side and connects to the logic board now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Apple does this all the time. The LCD digitizer on the iPhone 3GS and iPhone 3G are the same (same with 2nd and 3rd gen iPod Touch), only the connector is slightly changed. The LCD on the iPad and iPad 2 is the same, only the frame around it is different.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have also confirmed that iPad 3 digitizer works on a 4.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yea be careful when prying on the lower left of the home button, there is a thin ribbon cable there for the home button that can easily be damage.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes, iPad 3rd gen digitizer is the very same as iPad 4th gen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
NO, it's not. Just because it works, doesn't make it the same... the OD of the glass on the Gen 3 is smaller than the Gen 4.
댓글 달기
귀하의 답변을 추가하세요
WFM 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 11,864
