주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
질문 마감됨
How to tell which HD has the System on it?
How can i tell on a mac mini server which HD has the System on it? I only want to replace the System HD for an SSD.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
1. Go under the Apple to System Preferences > Start Up disk , and that will tell you what systems are on what drive.
2.; Go under the Apple to "about this Mac", the front page will give you your start-up drive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I assume you have a dual HD setup with matching HD's (same size & same vendor).
You can use Apples System Profiler application to ID the drive by it's serial number using the amount of used space as a guide on which drive via the desktop the first listed drive is typically the one with the OS on it. Go to Serial-ATA section to see the drives S/N.
Once you open the Mac Mini you can ID the serial number on the discrete disk drive.
But before you do that, do you have a external case to house the SSD in so you can copy the OS over? If not, you may need to take the non system disk out first to put the SSD in to then move the OS over that swap the disks around again so you have the config you want.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I've re-read this answer 4 times. It's as clear as mud.
Hopefully my correction makes it clearer. In dual drive setups with the SAME drive in both bays it's the only way I could figure it out. Yes, you can use the Start Up control panel if the drives are different sizes.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 300
