주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
질문 마감됨
Only top of screen is visible, rest is white/negative
After replacing the battery and re-assembling my ipod touch 4th gen, only the top of the screen (where the battery status indicator is) is visible, the rest of the screen is bright white/negative colored but i can still read the text. All other functions are good. I tried to disassemble the ipod twice but the screen remains the same. Is this the LCD or something else?
Thanks in advance!
Greets.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Its the lcd.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have an Ipod touch in my shop right now with the same issue. I pressed the home button fairly hard 3-5 times fast and the colors shifted back, not sure if this will salvage it but worth a shot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for the answers! I tried to press the home button as you said but this didn't solve my problem, I ordered a new LCD yesterday so I hope this helps
댓글 달기
yes, you can put the "invert colors" function for better readability on the triple home button click. but then the display would be completely inverted. since only a part of your screen is inverted it is definitely a broken lcd.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 423
