주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
LCD Stress pressure marks after installing a replacement screen
I had bought several lcd + digitizer replacements from different seller around eBay. Some of them send good lcd + digitizer replacements and after several purchases some lcd + digitizer replacements have this flaw when applying a little pressure around the lcd + digitizer replacement.
And is that after installing them they will show some stress marks on top and bottom of the lcd + digitizer replacement when applying a little bit of pressure. (Pic Related)
How can I know that a LCD is bad without installing them. I buy bulk orders from time to time since i own a repair shop.
Or anyone has a way to solve this issue?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
By the way Robert where do you get your Bulk orders ? I have a repair shop too and do the same .
댓글 달기
답변 2개
선택된 답변
This has to do with not correctly cushioning or applying adhesive to the underside of the screen. Mine does this as well and it is a common error when doing it. To get it done correctly try using a small amount of tape and super glue to hold the screen down.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Kevin,
Do you mean using tape/super glue during the application of glue or after (when the marks are present)?
How would you suggest avoiding this error when applying the glue?
Thanks so much h!
댓글 달기
Robert there is a way to test an LCD Digitizer without installing it, first, remove the back cover of your phone, then remove the steel cover plate that covers all of the ribbon cable connection points at the top by the camera, unplug the LCD Digitizer connections and carefully move them out of the way far enough to plug in and test the new LCD Digitizer, there is a (jumper) Ribbon cable made that makes this process much easier, https://www.gounlock.com/details.php?ite... I use it to test every screen before installation !
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 9,630
