주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
Is there a way to Test Screens?
I have been fixing iphones for a while now, and every one and a while i stumble across a broken screen. It is a big pain to take apart the device every time there is a faulty screen. What is the best way to test the screens without having to take the phone apart?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Yes, but there a bit expensive and not worth it unless your a repair shop and doing repairs on the daily.
Link here
I found one above at the link but im guessing there in that price range
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Do these actually work? Because a lot of the time I tend to test screens when performing the repair and they are fine but then develop an erratic touch issue the next day. How can I prevent this from reoccurring?
that looks like a screen defect. might want to check with your vender
They do kind of work. I own the multi phone model and still have to revert back to testing "bad" displays on actual phones to make sure they are bad.
댓글 달기
가장 유용한 답변
I use an old iphone with a bad esn. I removed the logic board and taped it down to a piece of cardboard and attached a dock connector to it. When you plug in the charger the screen will light up.I can easily plug in each lcd before install to verify they are good.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Austin this is what i use in my shop, https://www.gounlock.com/details.php?ite... I have an I 4 for my personal phone so I just remove the back and the wifi plate with my phone powered on, unplug the LCD Digitizer, plug in this jumper to my board and then to the new screen to test it, it works great and is less than $ 9.00 !
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
like he said before in his description he does not want to take apart his phone to test.
댓글 달기
귀하의 답변을 추가하세요
Austin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 8,049
