주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerShot SD1000 Digital Elph는 7.1 메가픽셀과 3배 광학 줌을 갖춘 디지털 카메라입니다.
"No Memory Card Error" What next?
이미지
이미지
이미지
이미지
Hello Everyone. I am new here so bare with me.
I tried all the "WONDERFUL' toothpick tricks and what not, to no avail. I still do not have successful results.
I disassembled the camera completely.
I am attaching some pictures to see if anyone sees something that I am missing. Something I am overlooking. Also, is there an option to fix the memory card slot…ie. Soldering or replacing it?
Your comments are welcomed and appreciated
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I assume that you originally tried more than one card, just to rule that out as the cause. You can replace the card reader, as long as you find a proper replacement. This one should be a standard one, so I would try to scrounge a broken camera and replace it. the soldering will be somewhat tricky and will require a bit of practice :-) but it can be done.
의
댓글 달기
답변 2개
선택된 해법
One of the contact pins are probably bent or mashed in.
The way SD card slots are soldered to the PCB makes it nearly impossible to replace. Machines, not man solders this stuff together when it's made.
Your best bet is to get a good main PCB from a junker SD1000 camera on eBay.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you very much for responding.
I went ahead and purchased a new PCB on Ebay.
I really wanted to try to replace the memory card slot but as you said, it can be really tricky and besides, I did not have the correct solder pin.
의
댓글 달기
이미지
Mission Accomplished.
What shall I get myself into next?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Excellent, great job.
의
Thank you very much. It was interesting.
의
댓글 달기
답변을 추가하세요
Janet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 21
전체 시간: 2,643
