주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 노트북 15 인치 화면
320 질문 전체 보기
dim backlight after my PowerBook fell down.
two days back my powerbook g4 fell down. unfortunately its backlight is not working but my harware is working well and i can see my screen display in a bright room. I m a medical student and dont know much about computers. please help me understanding and solving my problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
You've likely damaged the backlight or the inverter board. Inverter boards are not that expensive, however it is a difficult DIY repair. Backlights are not really a DIY repair but replacing the entire LCD (with backlight included) is. You might see if you can find someone/ someplace who could do this for you.
AS A WORK AROUND an external monitor should still work for you so you could use the laptop at home. iF an external monitor doesn't work then your problem is not with the backlight at all, but more serious.
If this answer was helpful please remember to mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
Despite popular opinion, inverters themselves almost never go bad. Most often in this scenario it's the screen, but it can also be the inverter cable. If you see light on the screen at any point when you flex the screen hinge, that's a pretty good indication it's the inverter cable. I would replace the inverter cable first, because it's cheap, and then next the screen. It can also be the backlight circuitry on the logic board, but it's far more often the screen or the inverter cable.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Supertramp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 337
