주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20012 질문 전체 보기
Faded screen in the middle of LCD. Prominent at black screen.
Faded pixels in the middle of the lcd of 13" macbook pro early 2011. Keeps expending and feels like screen being discoloured in a particular area. much prominent in black screen. What shall be done for this
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Do you carry your MacBook Pro around a lot or place items on top of it, such as books and stacks of papers. The light faded areas that I see on most Macs are results of pressure applied on the back of the display during transport or just placing things on top of it. I used to use a 17" MacBook Pro in schol and I would place textbooks on it which caused it to develop a bright spot that kept getting bigger from the centre of the screen. You can also get it from some bags, or just about anything that applies pressure. Another way this can occur is with heat. Do you place your computer under a hot area or set hot drinks/plates on it (seems kind of strange but people have done it before). Those are the main causes that I have found of faded LCDs and bright spots. It cant really be undone if this is the case, but it can be stopped.
Hope this Helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gaurav Verma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,855
