Can the optical drive from an A1095 be installed into an A1150?
The optical drive in my MacBook Pro A1150 died. I have an old PowerBook G4 A1095. Can I install the optical drive from the PowerBook into my MacBook as a stop-gap measure?
좋은 질문 입니까?
좋은 질문 입니까?
The optical drive from your A1095 PowerBook is too thick to fit into your MacBook Pro, unfortunately. Of the original MacBook/MacBook Pro line, only the 17" MBP's can accommodate the 12.7 mm thick drives.
Sorry!
해당 답변은 도움이 되었습니까?
+1 Ralph
The PowerBook G4's use PATA Optical Drives, and most likely has a 4X or 8X SuperDrive. The A1150 appears to be a PATA drive as well. It should be compatible, unless the thickness is a problem.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,766
