주요 콘텐츠로 건너뛰기
A digital SLR camera by Nikon released in 2007.
5 질문 전체 보기
When shooting a long delay before the picture is taken.
When taking a photo the camera delays between pressing the release and the picture being taken. I have set the camera to completely manual, exposure and focus, and it still delays. It appears to start doing this after warming up. Is this a processor problem or another part? If this is an inexpensive repair then I would do it. Any advice would be helpful.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Check your settings again to make sure auto focus and focus assist are disabled. Also set the AF setting on your lens (or camera body) to manual focus. In manual exposure mode, set your shutter to a relatively high speed (anything above 1/125). It sounds like your camera may be trying to focus before shooting.
Another possible problem may be with your media. The camera may have problems trying to write to the card. If you have another card, substitute it and format it in the camera. If you don't have another card, back up the images then do a low level (full) format on a PC, then format again in the camera. The low level PC format will totally clear the card and will check to see that it's writable. Formatting in the camera will set the proper file system and folder structure.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
John Krill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 867
