주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
399 질문 전체 보기
Bypass Power Button To Check Logic Board?
My friend dropped cream on my macbook pro.
The magsafe is giving the green light.
When I press the power button it does not start.
Is there any pads I can short to check if the logic board in turning on.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Yes there are... You realize you can blow the logic board forcing power up if the board is not completely clean and dry? They have not moved since the answer to this Question.
If this answer was helpful please remember to mark it accepted.''
해당 답변은 도움이 되었습니까?
점수 2
3 댓글:
I have tried those pads but no luck, I have disassembled the logicboard, I am getting a green light from the magsafe the fans are connected but it does not turn on.
There was some oxidation near the keyboard connector, I cleaned it with a brush.
How do you clean liquid damaged logic boards ?
There's a whole set of advice... soft to medium brushes, dielectric contact cleaner, 99% alcohol... let it dry well (low humidity - 72 hrs)... look for a (i) power on symbol near the contacts or it may say prbn... bridging between contact #5 & #6 on the top case ribbon connector may work.
댓글 달기
귀하의 답변을 추가하세요
mbaig 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,629
