주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
262 질문 전체 보기
질문 마감됨
Ds doesn't recognize game
Game was put in upside down and when I pulled out (with plyers b/c stuck) the pins inside bent. Can put in a game and eject fine but DS doesn't recognize that there is a game. I opened up and bent pins back down but there is one that is too bent and fails to make contact with game so I'm sure this is the problem. Where or how can I fix. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Joe, if your pins are bend or broken, and can not be corrected, you can try to replace the card reader. Follow this guide to remove your motherboard. Then you will need to desolder the old reader and install the new one. The part is available at places like this as well as others.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 541
