주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
Why is my display screen in black and white only?
I resently replaced my broken touch screen....since I put the phone back together I only get black and white images on my screen .... All buttons, apps and screen work perfectly... I just don't have any color.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 3개
What a wacky problem!
It happened to me too. Its on my iphone 5c. When I push home 3x I get camera. Any suggestions?
I found that screen in settings. Thank you
댓글 달기
답변 6개
선택된 해법
Is the screen actually in black and white or could it be that its in reverse black on white contrast mode http://grab.by/Zgb
if it's the latter you can find the accessibility settings in your iPhone and turn it off.
이 답변이 도움이 되었나요?
점수 9
댓글 4개:
Stitchrobot - You're awesome!!
which one is the home button?
What is the home button?
Mine is doing this but I have a Google Pixel 2
댓글 달기
Correct answer in my situation… Press the home button three times in succession and it will bring a menu option that says
"voice over"
"Invert colors"
"Zoom"...
You will most likely notice that the "zoom" option is checked… UNCheck this option and your screen will go back to colors!
Yea!!
이 답변이 도움이 되었나요?
점수 6
댓글 5개:
Awesome! Thank you so much as this has helped me!
Other experts could not fix problem, but you sure did, and many, many thanks
Thanks a bunch
Great brother,
It worked for me....thanks dude !!
Thanks I learned something New Today
댓글 달기
tap your screen 3 times with three fingers. A menu will pop up. Touch choose filter and set to none.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Omg thank you so much! Todd Ramsey ☺
댓글 달기
looks like a cable issue to me (connector) - unless it's a broken screen.
But hey, colour is overrated !
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I have LG Aristo that suddenly turned black/white
I tried everything, turning it off and back on, adjust settings, searched internet for help, etc...
Nothing seemed to work
)))UNTIL(((
I pulled down the screen at the top which give notifications and at the very top has signs of features that can be turned on and off by touch.
ie: WiFi strength, Sound, Bluetooth, Location, Rotation, Sync, Flashlight, Airplane Mode, Data, Battery Saver, Color Inversion and "COMFORT VIEW".
Clicked on 'COMFORT VIEW' and (((POOF))) everything went back to color.
Felt like I was in Wizard of OZ. LOL
Hope it helps fix your issue.
Have a GREAT Day!!!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This solved the problem completely!
댓글 달기
On the LG XPad 2, I pressed the Hot Key once and that put it back to color.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mytech 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 49,697
