Has a burnt smell
Motor is on but not spinning and has a burnt smell
좋은 질문 입니까?
I'd open it up and see if you can isolate the smell.
Motor Coupling
If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Motor
If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
해당 답변은 도움이 되었습니까?
My washer Kenmore 90 series it washes its spins it drains but it smells like a burning smell comes out
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,778
댓글 1개
Have you checked the motor coupler? What have you checked on thus far?
oldturkey03 의
