주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
Dropped in water now won't ring and bell symbol missing
I have dropped my iPhone in water. It is now completely dry and everything works fine except the switch on the side that switches from ringing to vibrating. The phone will still vibrate but when switched to ringing the bell symbol doesn't appear and the phone will not ring. What part do I need to replace to repair it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sorry to say that if you want to take care of this right you need to do a real water treatment to it, even though most of your functions have come back they will stop working again with time and your phone will stop working all together, try this, Repairing iPhone Liquid Damage, its a guide for an I 3 but use these methods on your 4, and here is a teardown guide for your 4 S, iPhone 4S Teardown, if you do this I would bet your other problems will be fixed also, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone 이미지
안내서
난이도:
어려움
1 - 2 hours
iPhone 4S 이미지
안내서
iPhone 4S Teardown
난이도:
운영
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 2,738
