이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개
What OS are you using? Have you checked in device manager, or similar, to see if your network card shows up? Any exclamation marks on your devices? When did all this start? Have you reset your modem? Do other device connect to it properly?
Hi, wikky is correct about the buttons and the wi-fi button is on the front of the unit on the right side facing the screen. I am including a link to the service manual for your unit so you may identify everything. Good luck.
댓글 1개
oldturkey03 의
