주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
White screen after drop
I dropped my iPod and now my screen is white. The iPod still makes sounds, gives me notifications, and the buttons do what they're supposed to.. I can even unlock it by sliding my finger across it, but my screen it just white. I can't see what I'm doing.. Help?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Hi
If youve dropped it then its likely the screen has gone faulty and will need replacing.
There are guides on ifixit to help you replace the screen but you do so at your own risk as its not easy.
You can also buy the part from ifixit
Regards
Update
Hi you can pick up a replacement screen for about $30 from ifixit found here
iPod 4G Display
there are plenty of guideas around to assist, but i do warn you its quite difficult if youve never done it before
Regards
The display is a 160x120 pixel 2" LCD screen. 이미지
제품
iPod 4G Display
$29.99
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thank you! Do you have any idea of how much that will cost me?
About $30 probably if not less
댓글 달기
가장 유용한 답변
Hello! It may be the LCD is damaged or the connector may have just popped loose. I would follow the guide here to open the ipod up and just reseat the connector first. May save some money. If that doesnt do the trick than I would order a replacement screen and replace. Not terribly difficult to do. The screens usually run about $15-$20 online.
Hope this helps
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lace 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 4
전체 시간: 2,004
