주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
any differences between the SSD discs on 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Mikkel - SSD's are Solid State Drives are not disks as in Hard Disks.
You sound like the Saviour character on Walking Dead, correcting Enid for saying 'Veggies' when she should be saying 'Vegetables.'
댓글 달기
답변 2개
선택된 답변
As to your Q - I would recommend getting an external case to hold your old SSD from your now dead MBPr and leave your new system alone. If you want to increase the SSD's size bigger than what Apple sells then open it up to put the bigger SSD in. Once you get the SSD installed in it's case then you can copy your files over and still have a neat backup solution.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
That's a great idea, but what is the answer to the OP's question?
I'm pretty sure they're not interchangeable but hopefully somebody knows the odd balls which can be swapped..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mikkel Christiansen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 468
