주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
iPad camera wont work after repair?
I replaced my iPad 2's touch screen digitizer, and in the process I tore the ribbon cable to the volume/mute/power button. I went to a local store (eTech Solutions) and they had the ribbon cable in stock for only $20, so i bought it. After I replaced the cable (after watching plenty of youtube videos and reading guides on ifixit.com) and had the iPad back together and now neither the front or back camera work. I have two camera apps and both of them say that the camera isnt usable. Any ideas? Please and thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
unplug the cams from the motherboard and reseat them. I have had this happen. It is also possible that one of the cams has an internal short, and is keeping the other one from turning on.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yup, me too. Most things seem to work so far, but the screen side caméra seems dead thé camera apps, (I have 2) won't switch to the screen side camera. I did have a problem pushing the camera cable connecter tab back down flush.
댓글 달기
I have been replacing screens on iPad 2s and have come across 2 iPads with rear cameras not working.
In each unit the camera app brought the"iris" image on the screen. In one, the iris briefly opens but doesn't show a view and then closes again quickly. In both iPads I have replaced the rear cameras but nothing has changed. I tried reseating the cameras several times, with and without screwing down the covers.
I have tried software upgrades and complete resets.
Can anyone suggest what this means.....logic board replacement or just put up with not having the rear camera. After all, the front cameras still work for FaceTime at least.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same issue with the rear camera not working after replacing the flex cable. Anyone solve this issue?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Make sure you hear a click when you snap the camera back on. Align the camera right then push the right side flat till you hear it click. Reboot iPad then try camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks riverarf .....I have just upgraded iOS to 8.1.3 and "BINGO" the camera is now working like it never failed !
It may be co-incidence but it's worth the try.
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 7,612
