주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
Battery replaced, no earpiece sound
Didn't find an answer, so...
I replaced the battery according to instructions here. But when I got to removing ribbon cable 3 with white clip, the clip started coming apart anywhere i GENTLY lifted it (as instructed of course). Was as it the plastic was old an rotten. But the cable slipped out and I actually slipped it back in on reassembly.
But alas, no sound from the little speak at the top of the screen. Is there a possibility the ribbon cable does not correctly connect even though it appears to be slipped into place?
I can hear it if I put on bluetooth, turn on the speaker, or use an earphone in the jack.
Also did not see the screen adapt to the surrounding light but I was not really testing that.
And is there a way to fix that little white clip so it works properly?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
sounds like you have damaged the ribon cable. inspect for even the slightest tear, as that will have a major inpact on both the ambiant light sensor and the top spekaer.. when in a call does the screen auto shut off when you put it to your face if not than that flex cable needs to be replaced... something like this wiil be fine.... http://www.sunsky-online.com/view/16923/...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I wii probably have to replace that cable then, but what about that white clip that seems to crumble at the slightest attempt to lift it for sliding the cable in and out?
I never actually lifted that clip since it cracked in each place I tried to lift it.
댓글 달기
I tried to have a #3 connector assembly (which you CAN buy) replaced but it was an impossible job even for a good technician. You might try sliding a small non-conductive shim under the #3 cable to add upward pressure to the cable .. it might work. Worst case scenario .. just use the speakerphone.. somehow the sound carries through the phone and up to the earpiece. Hey.. it works!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 204
