주요 콘텐츠로 건너뛰기
Understanding the diagnostics log.
I would greatly appreciate it if anybody could help me to pinpoint these errors (piece of hardware, sensors location, etc. log below).
  • Temp (TC0D) - CPU 0 Die Temp (test #1) - Sensor Reads Within Operating Range - Check to ensure that sensor reads within operating range. ERROR -- 1 [Unable to read sensor] -- (1.00) TEST FAILED
  • Temp (Th1H) - Heat Pipe 2 Heatsink (test #1) - Sensor Reads Within Operating Range - Check to ensure that sensor reads within operating range. ERROR -- 1 [Unable to read sensor] -- (1.00) TEST FAILED
  • Temp (Ts0P) - Skin 0 Proximity (test #1) - Sensor Reads Within Operating Range - Check to ensure that sensor reads withing operating range. ERROR -- 1 [Unable to read sensor] -- (1.00) TEST FAILED
Thanks!
Update
Left thermal sensor was broken, causing TC0D & Th1H. Ts0P (Skin 0 Proximity) error still remains, it isn't one of the 3 thermal sensors. Any ideas?
FnX
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
가장 유용한 답변
Has the machine been "operated on" by you or someone else not mac certified?
If so check the connectors on the logic board around the heat sink and fans. It's possible they "look" connected are are actually loose. Inspect the wires for breaks at the ends you can see.
If all that looks ok I believe you have a bad logic board.
Good Luck,
N.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
FnX 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 6,127
