주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Is Fusion Drive possible on 13 inch Mid 2012 MacBook Pro?
Just wondering whether or not it is possible to upgrade to a Fusion Drive on the 2012 13"macbook pro. ie. taking out the optical drive and replacing it with an SSD and pairing it with the HDD.
Does anyone know if Apple might be planning on pushing this change out there in the near future?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
An Apple Fusion drive requires Mountain Lion and a system who's firmware supports it. Apple does not offer a Fusion drive currently on this system and creating a similar setup with you own HD/SSD is not possible either (firmware won't let it work).
With that said, you still can make a dual drive config HD & SSD. But, you'll need to manage the discreet files on the SSD manually.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It's possible. And by saying possible it is no where near easy. You have to dive into Terminal and start tweaking OS X code. Which can be very dangerous. You can search the web for DIY Fusion Drives and many of the articles explain a lengthy process to get it to work. Here is just one.
http://www.zdnet.com/diy-fusion-drives-n...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rich 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 4,656
