주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
iPhone 4 WiFi not working (doesn't see any network)
Hello, I dropped my iphone 4 from the 4th floor; I changed the LCD, the middle frame and the battery by myself
Everything works fine except the front camera (which I'm about to replace too) and the wifi
The iPhone just can't see any wifi network even if it's next to the router; the small metal piece on the top of the metal plate covering all the connectors on the top of the logic board is in its place and so is the grounding 4.8 mm screw
The only visible damage to the logic board are two missing nuts for the screws holding the above mentioned plate (the smallest one plus the one above it)
Have you ever experienced such an issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Can i stll Getafe the email with no wifi
댓글 달기
답변 2개
가장 유용한 답변
the top of the case and the shield bracket serves as the wifi/BT/GPS antenna. Make sure everything is correctly in place. the washer under the screw is touching the gold point on the logic board, the long screw is in place, the standoff screws serve as the ground. and there is a meal contact pin to the left,make sure it is intact
image is taken from nikkeibp chinese site, for illustrations only
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi
The backplate at the top is the WiFi shield and in my experience if screws are missing from there MOST of the time WiFi will not work, you will need to ensure all screws for that black plate are in place and screwed into the motherboard
Regards
Ali
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
As I said the nuts are gone, so if you are really sure the screw is the cause, I may try to find a way to reestablish contact
If anyone could try to remove that screw from his iPhone 4 and confirm that wifi does not work, I would have the confirmation that is the problem
The screw I'm talking about is the left one circled in orange here
https://www.dropbox.com/s/e1pdw1zwrjy9co...
댓글 달기
귀하의 답변을 추가하세요
Jacopo Scarpellini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 19,674
