주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
204 질문 전체 보기
eSATA mod-- need adapter, cables?
My MacPro 1,1 has finally died. My main storage is an eSATA RAID, and I know there are Thunderbolt adapters, but they're expensive. Have read much of eSATA mods on earlier mini's, some seemed to require removing optical drives, etc.
Does anyone know if, with a single boot drive installed, there is a *spare* internal SATA connector, to which I can connect a SATA to eSATA cable, find some way to route it outside the case, strain-relieve, etc., and connect to my eSATA RAID? Or is the iFixit two-drive adapter needed, even though I'm not installing a second drive inside the case?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Feeling a little dumb to solve my own problem, but maybe it saves someone else the research: For a new mini or any other model, USB 3 ports are numerous. For $25, a USB3-eSATA adapter (e.g. http://eshop.macsales.com/item/NewerTech...) makes much more sense than a mod.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Does this work with 3GBs esata to esata-to-usb3.0 adapter? I tried one from amazon -unbranded- and it does NOT seem to work w/ a G-RAID 4TB RAID 0. Thanks for any info Paul
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tom Bair 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,952
