주요 콘텐츠로 건너뛰기
iMac은 Apple의 올인원 데스크탑 컴퓨터 라인입니다.
8382 질문 전체 보기
질문 마감됨
Why does my iMac keep freezing
I will be working on my iMac and it will just freeze. when you push a button, the mouse icon will show that colored circle, likes it's thinking. You cant switch screens, open or close any windows. You have to hard start the computer. The more you work on the computer the more frequentlly this happens.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Which iMac? Look on the bottom of the stand for the info.
댓글 달기
답변 1개
Do the fans run loudly most of the time? There is not much space inside an iMac, and when dust starts to build up, they overheat. If you hard start it, the parts will still be warm, so you will get even less time out of it than the prior power on.
You may need to disassemble the computer and blow all the dust out from the fans and off the board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,534
