주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
No Service when 3G is enabled.
Dear iFixit,
I am having a problem for a bit with my old 3GS: I get very poor connection when 3G is enabled. Basically, I have some network for a few minutes (10-15, it varies) then switches to "searching" and then "No Network". I usually don't get any network back.
It is interesting to note that when 3G is off, I have absolutely no problem getting a stable GPRS/EDGE connection.
I am currently running iOS v6.1, but I have this problem for ages.
Therefore my question is: Is there a different antenna for 3G and EDGE/GRPS? Would you recommend changing it?
Regards,
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Hello,first off all sorry for bad eng. but ill try to help you
So i saw a lot users od iphone have problem with iphone 3g/gs. No service on 3g network or when its off,i have that phone also and i have solution that worked 100%
problem is on signas switcher that is located on this picture you can see them: lower part of iphone.
http://i87.servimg.com/u/f87/13/27/39/62...
So here it is,take a hair dryer,a turn it on,heat this chips for about 10 sec,then whit your fingers push chips on logicboard,get iphone back on,go to settings-reset then reset network settings,and its workig :)
if its now working try to heat and push chips again
please share this solution becouse i cant see any other solution for this problem
and please correct my words if there is something wrong
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
jurica, nice answer, but can you describe the location of the "signas switcher" a bit better?
I do it by the way,but it does not work.
I must push chips on logicboard more powerfully?
댓글 달기
Hi,
i had the same problem with an old 3GS. It was an error in the logic board, without a chance to fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
can this problem be solved in same manner for android phones?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ace Spizzer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 8,302
