주요 콘텐츠로 건너뛰기
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 질문 전체 보기
질문 마감됨
Black screen, sometimes moving it let me see something
Hello
There is this Toshiba Satellite C660-1MG and the screen is black when I turn it on. From the border there is some white moving.
Moving the screen (opening and closing it again) one time on a million let me see something, but then it makes a little movement and freezes and goes white or black.
What can be broken and how can I fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Most probably the connector that goes from the screen to the motherboard is broken try pushing the bottom of your screen a bit harder with your fingers to see if it flickers back to life if it does then u need to change the cable, its not that expensive usually.
Also try to connect an external monitor to see if u have video signal
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 318
