주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
No sound from external speaker!
I have been having this problem for over a week, my iPhone 4 will not ring, sound the alarm, or play music. It only vibrates and makes a very staticky sound.. Has anyone has this problem and fixed it? My phone is only about a month old!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thank you for all your help! I am going to try everything mentioned
댓글 달기
답변 5개
가장 유용한 답변
I agree, replacing the loudspeaker is cheap and SUPREMELY easy. Here's an instructional on how to do it https://www.youtube.com/watch?v=gjoi0u3y.... Also there could be an issue with your docking connection. Try cleaning that.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
I had once this problem.
I disassembled the speaker enclosure and put some electronical cleaner (spray) in the speaker...
After letting it dry, I reassembled the phone and all worked fine again....
Hope this will help you
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My recommendation is to replace the loudspeaker. It's very cheap, and fairly easy. Ifixit has a great guide for that, if you aren't afraid to open her up. The part is definitely under $10.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Had this problem for almost two months. Could hear phone ring and use speaker phone , but could only hear music and apps via headphones.
Tried all those cleaning solutions, wanted to downgrade OS.
Then it got fixed and I think it was this, as crazy as it may sound.
I was nervous about having FindiPhone hooked up - my wife left hers in a restaurant and it was not hooked-up. So I checked my "Find iPhone" set up, paged the iPhone via "Find iPhone"- and ..... sound came out of the f*#$&ing speaker!
It's now all fixed - sound works in the speaker for all apps.
This is the only thing I can think of that I did that was different from all the other recurring loading, connecting etc. operations. Would love to hear if this works for others.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had this problem and first changed the headphone jack out and still had the problem.....with more searching I saw a post about the docking port causing this issue. I just changed the docking port and all works well now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 5,023
