주요 콘텐츠로 건너뛰기
Screen Black Out, otherwise perfect
Hi,
I have searched the forum for this issue, but can't seem to find a similar problem.
I have an iMac 17 iSight. No issues with vertical lines, dark areas or funny colours. The issue I have is that from time to time, well it's getting more frequent the screen will go black, the computer is still running and I can here volume increase noises and so on.
To counter this I attached a second monitor, which worked well, but now this is playing up and going black, I have checked it on another mac and its fine, the mini dvi is also fine.
I can gather that both screens are turning off at the same time, not separately. So the iMac is suddenly losing its ability to show the screen
Is this a graphics card issue, lose connection, something I can fix, I have reset PRAM, SCU and everything else I can think of.
This is not my main machine, it has Skype on as we'll as Office and hats it, so it's not being overworked.
Anyone had the same issue, as I said the screen is vibrant and clear....
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
if both the external and internal monitors exhibit the same symptoms, it is most like a graphic card issue. What are the last three digits of your computer?
Having that much difficulty getting a screen to stay on long enough to find out..... However last 3 are
serial 3HTAT
For some reason unknown, the serial number is not getting us what we need. Please look on the bottom of your stand and get us the EMC # and processor speed. Thanks
emc 2081 1.9g5
댓글 달기
답변 1개
선택된 해법
This machine had some of the capacitor issues of the earlier G5 iMacs. Next step would be to open it up and examine the capacitors for swelling and/or corrosion. Please let us know your findings. The capacitors are small can looking things.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
+the symptoms most certainly support the bad caps issue.
Would that effect the dual screen issue as well?
Don't mean to butt in here :-) Yes it could since it supplies the power etc to all of the video out.
Started to take the mac apart, however I am missing a screwdriver for the front screws... Shall update with an image of the Caps once I have had a look to get your opinions.
댓글 달기
답변을 추가하세요
Simon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 759
