주요 콘텐츠로 건너뛰기
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
82 질문 전체 보기
Nintendo DS does not power on.
DS doesnt power on. Orange light comes on when A/C is pluged in and battery charges. When i press power button the green light comes on and then top screen flashes and bottom screen doesnt come on, then the DS turns off. i checked the fuses F1 and F2 and jumped both fuses, but the same thing still happens. Does anyone know how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 4개
선택된 답변
There is a short in the system. Good chance you have water damage. Check the lower LCD backlight cable and connection. It is the small cable on the right under the larger video cable. The other small one is for the digitizer. There is also a good chance it is the ribbon cable that runs from the motherboard in the lower part to the daughter board in the upper part. Either that cable isn't seated properly or it has been compromised (broke).
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
There is an inductor that is poorly soldered on the board. If your good with a soldering iron it is a very simple fix. Google L2 inductor and you will find the info on how to do it
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This happened to me as well. If your fuses are okay then you should check if all your connection cables(flex cables,etc.) are all properly connected.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
how about just get a new battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Doug 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 9,495
