주요 콘텐츠로 건너뛰기
Fiat Chrysler Automobiles US LLC/피아트 크라이슬러 자동차의 Chrysler/크라이슬러 계열사가 제조한 승용차 및 기타 차량 수리 안내서 및 지원.
189 질문 전체 보기
My 1999 Chrysler Sebring JXI will not turn over?
So, I recently bought my Sebring JXI. It's a V6, and I seem to be having issues with it starting. It will turn over, but not start. I found out that it was not creating a spark, so I replaced the spark plugs and wires. Still won't work, so I replaced the distributor cap and rotator. Still no spark. So, I tested the fuel pump. It's working just fine. Now I take it to a shop. They replace the entire distributor. It works GREAT. I was super pleased, but now (not even a week later) it is repeating the issue. I have no clue what it could be.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Your vehicle uses an internal ignition coil with a dstributor all built into one assembly. Your vehicle uses a CMP Sensor or camshaft position sensor to tell the ignition coils when to fire. If that sensor is faulty then you get a no spark condition.
If the vehicle is out of time because of poor workmanship due to a mechanics own error then yes bring it back to the shop. Have the shop foreman supervise the diagnostic strategy that the mechanic uses. This ensures that your problem is fixed.
Is your problem fixed? Please tell me what was wrong. I have same car model and code errors left and right. first fixed the distributor, then the alternator, then fixed the crank position sensor, and now code erroring the dang distributor assembly again, Firestone repeated the distributor and now still is running craptastic... They are not sure what it is either. The code is still erroring the distributor assembly.
댓글 달기
답변 3개
가장 유용한 답변
Sounds like a timing issue to me. Especially after a full distributor replacement. If I were you I would take your car back to the shop and have them reset your timing and ensure all of the bolts are secured down tightly.
It COULD possibly be a computer error, im not to much into Chrysler but I am sure they can see if your ECM is throwing codes.
Just ideas
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
no spark relates to the camshaft sensor, if its faulty it
signals the A D S relay which cuts off fuel and spark .
댓글 달기
Check the timing belt , if u got one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Same thing here.. No spark, have new distributor, new crank sensor, wires, plugs, battery, have fuel pressure. Wtf. !&&*
No timing marks, if skipped couple teeth somehow would it prevent spark?
댓글 달기
i have a 1999 sebring and i have a bad positive jump start post in my fuse box what can i do to fix it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sarah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 8
30일 전: 20
전체 시간: 4,442
