주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
Black screen with stripes after replacing front panel.
I followed the guide to replacing the front pannel. Once I finished, i realize that the phone was probably turned on. After that, I have tried to hard reset it, but it didn't work. Sometimes the screen goes black with vertical gray stripes, sometimes not. What means that? Could be the fact that the phone was turned on when I was working on it a possible reason?
Many tanks.
Nico
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
If the phone was on when you disconnected the battery there is a chance something may have happened...but for it to be doing what you have described is strange. Have you tried re setting the connecting ribbons (with the phone turned off)? If that doesn't work it may just be the screen that may be faulty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I haven't tried to re set the connecting ribbons with the phone turned off. I should try it. Anyway, the screen was the older screen of the phone. Is there a chance to damange it while phone is turned on?
...and how can i turn of the phone if the touch and the screen doesn't work?
댓글 달기
It involves a little more work, but you could also try lifting the logic board off from the battery just enough to let the phone reset everything. Then putting the phone back together and turing it on with the display in.
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
I've already done it.
How did it go?
Nothing changed.
Try a new screen... I have a feeling that its a faulty screen.
Maybe the screen is faulty, but the phone is turned on right now. How can I turn it off?
댓글 2개 더보기
댓글 달기
Check the flex cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 7
전체 시간: 435
