주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
204 질문 전체 보기
mac mini stuck on white screen
hi i have a 2012 mac mini & think i have deleted everything including recovery all that it does now is white screen plus folder & ? icon cant get into anything else command + r doesnt do anything cant get internet recovery either any help would be much aprecciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
The flashing question mark means that the mac cannot find a bootable system. When you say that you think you deleted the OS by mistake, what did you actually do? Have you performed any repairs? If so, make sure your SATA connection to the board is in place.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
i wanted to get rid of email acount but couldnt so went to settings & deleted the restore partition by mistake then deleted everything i think so now there is nothing i can do to boot it
I'm afraid you are going to have to reinstall the OS. You have completely wiped the drive. Do you have a clone? Back-up with TimeMachine?
I have no backup at all is there a way to reinstall the os
댓글 달기
Did you register your Mac Mini on the first boot? if you have then you can do a complete install over the internet for the OS but you will lose ilife.
Shut down your machine leave for the a couple of minutes then press the power button at the same time holding the option key down, after a few seconds you will see two drives pop up on your screen click on HD recovery and follow the on screen instructions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
john 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,027
